Author Topic: Curb with pavement corner problem  (Read 10852 times)
NHimages
« on: July 09, 2025, 10:33:10 am »
We currently have a problem with our RC preset of a curb with pavement distribution on the inner curb, the first line of pavement seem to be ok, but when we had the second and the third it went wrong.
This happens in the corner of the preset, the pavement does not slice correctly and we have bad result with rectangular shape while with circular one the preset seems to work properly (see attachment).
Is there a way to fix the issue on the corner with a rectangular shape ? We already tried all modes of distribution in the default rollout but it did not work.
I attached the scene if you can have a look !
Thank you,
Guillaume
Re: Curb with pavement corner problem
« Reply #1 on: July 09, 2025, 11:13:12 am »
In this case, it’s recommended to adjust the Y Offset value instead of using Transform > Y Fixed Translation for the Segments. Please find attached a modified version of your scene demonstrating this setup. I hope you find it helpful.
NHimages
« Reply #2 on: July 09, 2025, 11:42:49 am »
Thx for your answer, it seems to be working better with the Y offset yes !
I was wondering if there is a way to now fix the "wrong slicing" effect on the corner of the pavement ?
I've done some test of default mode (attachment) :
- TILE made a fill effect with little square wich is not what we'r looking for
- SCALE is what I'm looking for but it strech the geometry too much and we don't have the effect of random anymore
- ADAPTIVE is also better but there is too much of deformation betwteen pavement stones
I don't really know what is the best option to achive the scale effect with the adaptive one !
« Reply #3 on: July 09, 2025, 01:26:47 pm »
Using the Corner input with the Bevel Corner option enabled should help avoid these issues. Additionally, slightly shortening the segments using the Transform Operator can improve the result. I've attached a revised version of the scene. I hope this helps.
NHimages
« Reply #4 on: July 09, 2025, 02:07:58 pm »
Thank you for the answer.
Yeah this version is definitely better, even if there is still some little problem the major issue as been solve.
Have a nice day !
Guillaume
