Author Topic: Concrete tiles  (Read 3583 times)
arch3d
    • arch3d.pl
Concrete tiles
« on: August 25, 2021, 08:33:49 am »
I would like to ask you for some help with style.
I have problem with top row. Also I would like to archive conditional ending corners depends of last row of default segment.
Many thanks
Michal
Re: Concrete tiles
« Reply #1 on: August 25, 2021, 10:46:19 am »
Hi Michal,
That's because of the following principle - in our Getting Started with RailClone guide (under chapter 9 - Create your first 2d array) you can find the following rule for building 2D arrays:
Rule 2: To avoid gaps, Segments should be the same Y length: Because the A2S array is a stack of L1S generators, if you use Segments with unequal sizes on the Y-axis in a row, the overall height of that row is determined by the tallest segment. The row directly above will be positioned after the tallest segment and gaps will appear.
By "swapping" axes (and X / Y Sequences) you can get the desired result. I hope that helps.
arch3d
    • arch3d.pl
Re: Concrete tiles
« Reply #2 on: August 25, 2021, 12:28:13 pm »
Hi Michal
Thank you for quick help.
I revised style. Now is much more simple
Now only problem is how to do conditional ending depending of last column in default section (it change if i drag XSpline)
Re: Concrete tiles
« Reply #3 on: August 25, 2021, 01:12:39 pm »
There's no need to use Start & End Inputs in this case. The Default Input in the Adaptive mode will do the job. Please find attached the modified scene - 210825_concrete_tiles_iToo.max.
arch3d
    • arch3d.pl
Re: Concrete tiles
« Reply #4 on: August 25, 2021, 01:32:14 pm »
Works perfect!
Thank you
Re: Concrete tiles
« Reply #5 on: August 25, 2021, 01:39:04 pm »
You're welcome ;)
