Author Topic: Corner issue with sloped facades  (Read 3199 times)
LH2287
« on: October 24, 2018, 02:25:33 pm »
I am building a facade similar to that (attached bellow). In the generator I have a default element for the glass and evenly element for the distance between the mullions. The facade has to be sloped and I rotated the geometry via X rotation option in the generator. My question is, how to fix the corner issue where the two planes of the facade do not intersect correctly. I tried making the generator mode to adaptive but it made a third plane on the facade where the intersecting corners should be.
Thanks for the help.
Re: Corner issue with sloped facades
« Reply #1 on: October 24, 2018, 02:28:49 pm »
That is "X rotation " limitation. You will have to use alternative method to build this facade.
LH2287
« Reply #2 on: October 24, 2018, 02:33:53 pm »
What method should I use instead? Every alternative method is fine as long the sloped corner is completed. The facade is curved at some places and then makes sharp corners. There is nothing I can think of and it's been an issue in the office for few days now.
Best regards
« Reply #3 on: October 24, 2018, 04:41:55 pm »
You can use slanted wall as geometry to begin with:
