Author Topic: rotation same distance  (Read 2966 times)
funk24
« on: October 24, 2018, 10:42:25 am »
good day
sorry for my bad English.
I have an array 2s object. the default object I would like to change the rotatin without changing the position. The distance in the axis should always be the same.
Is that possible?
Re: rotation same distance
« Reply #1 on: October 24, 2018, 11:09:26 am »
If you define the General > Fixed Size of used Segment, having the Scale Segment option disabled, you can adjust under Transform > Rotation without affecting the distance of these “rows”.
Hope that helps.
funk24
« Reply #2 on: October 24, 2018, 01:05:21 pm »
Thank You.  :)
