Author Topic: corner railing  (Read 2616 times)
djibvongenf
corner railing
« on: July 10, 2023, 12:40:26 pm »
Hi All,
Any idea why this happened and how to fix it?
i have two meshes
The vertical element (wire green) and the horizontal (wire pink)
i cannot find a way to close gasps and corners..
thank you
Re: corner railing
« Reply #1 on: July 10, 2023, 12:52:26 pm »
Please try adding negative Left and Right Padding values to the corner piece. Alternatively, you may want to add the railing top as a separate generator. So you'd have one generator to add the posts and a a second to add the handrail.
I hope that helps,
djibvongenf
Re: corner railing
« Reply #2 on: July 10, 2023, 01:14:16 pm »
Thanks a lot for this brilliant and working solution.
Maybe you have another one hidden under you hat to get rid of the bevel. Which i thought i could manage but obviously not.
djibvongenf
Re: corner railing
« Reply #3 on: July 10, 2023, 01:24:18 pm »
thank you again for your great and fast support... bon appétit!
i found the correct menu. :)
Re: corner railing
« Reply #4 on: July 10, 2023, 01:55:03 pm »
Aha! Great, glad you fixed it. If I can help with anything else, please let me know.
Best,
