Author Topic: Create This Limestone Wall  (Read 10968 times)
Arslan
Re: Create This Limestone Wall
« Reply #15 on: October 25, 2023, 01:41:36 pm »
I think I fixed it by using a different A2S generator. I hope it works for you.
Keith678
« Reply #16 on: October 25, 2023, 02:04:56 pm »
That's brilliant well done.
All in one Railclone which is always nice.
I somewhat understand the transform and how they push and pull the segments but could you explain your workings in the image I've attached. Just want to fully understand what's going on so I can reproduce it in the future.
Arslan
« Reply #17 on: October 25, 2023, 03:34:56 pm »
My English is not very good, I tried to explain with screenshots.
As a basic approach; It would be easier if you make these adjustments on a simple rectangular spline first and then try to work on the main spline.
Keith678
« Reply #18 on: October 25, 2023, 03:41:03 pm »
That's amazing. You went above and beyond. It makes perfect sense.
Thanks again. Now I'm just figuring out the best approach for materials. I've already hit a wall, no pun intended, where the edges are visible on the object for some reason.
But don't worry I've already taken a lot of your time.
Keith678
« Reply #19 on: October 26, 2023, 04:29:07 pm »
Thanks to everyone that helped. Happy with how it came out. Just need to fix a few glitches with the segments and should be good.
