Author Topic: Creating an Acoustical Tile Ceiling  (Read 17905 times)
Jesse Martin
« on: January 15, 2014, 02:57:43 pm »
I am trying to create an acoustical tile ceiling, but having some issues with centering when the spline dimensions aren't a multiple of the tile size.
I am using 24" ceiling tiles, trying to fill a 13'x13' area.
Is there any way I can get this to center properly so the tiles at the side and top are all the same spacing?  I can manually create a shorter tile to start with, but I was hoping to make this a library item that didn't need to have custom pieces each time i use it.
Thanks!
-Jesse
Re: Creating an Acoustical Tile Ceiling
« Reply #1 on: January 15, 2014, 08:07:20 pm »
Hi Jesse,
I've had a quick look at this and I've attached a revised version of your file with a possible solution. As you can see I've split the style into 4 generators, this enables me to use the X and Y evenly slots with the mode set to Justify to automatically center the grid lines . I've used the same settings for the tile generator but with empty segments in the X/Y evenly inputs so they are only  being used to position the tile segments.
Hope that helps.
Jesse Martin
« Reply #2 on: January 15, 2014, 08:25:28 pm »
Works like a charm!  Thanks so much, Paul.
« Reply #3 on: January 15, 2014, 08:27:51 pm »
My pleasure, glad to help out.  :)
