Author Topic: "CUREVD TOP BUT A FLAT BASE"  (Read 7705 times)
EM4616
« on: October 05, 2022, 11:57:06 pm »
Thank you very much for the last ask itoo video,
The question about the "CUREVD TOP BUT A FLAT BASE" was very informative.
It was probably exactly what I needed, but unfortunately I was not able to achieve this result.
I'm trying to make a facade with an upper slope but the bottom of it ends in flat ground.
Along the front I spread an element that comes out of the wall when I used RC SPLINE.
The alignment of Z on the ground looks jagged, like a zig zag and I don't know why.
In addition, I would be happy to know:
1. How do I actually determine the Z I want (if it is not zero)? That is, let's say and I want the front to align at a height of -200 CM...
2. Is it possible for the bottom alignment (the base) to be according to some spline that I determine and not according to a specific coordinate....
Attach a file.
Thank you !
Re: "CUREVD TOP BUT A FLAT BASE"
« Reply #1 on: October 07, 2022, 10:08:47 am »
The jagged base happens because the segment is below the spline and the Vertical Top/Bottom measurements are always measured from the spline upwards. The solution therefor is just to move it above the spline a tiny amount. For example:
- For each segment, add a Translation > Z value of 0.02cm
- Set the Vertical Bottom Value to 0cm and the Vertical Top value to 0.01cm.
For your other questions.
To determine the Z angle you want, just move the RailClone object. You'll probably need to reselect the spline afterwards but it'll always scale the RC object's position on the Z axis. In your example - move the RailClone object to -200cm on the Z axis and then reselect the spline to force an update (or click Build from the Display rollout)
I'm afraid not at this time - it's on our wish list, but creating an array between two splines that works well is quite complicated.
I hope that helps,
« Reply #2 on: October 07, 2022, 11:08:46 am »
Easiest way would be to use one (second) splane to create a surface and use buld in macro Surface To Spline Distance to determinate Z size.
EM4616
« Reply #3 on: October 21, 2022, 12:30:31 pm »
Thank you very much everyone
It's not perfect. But it definitely helps me right now.
We will wait patiently for the next updates :)
