Author Topic: Different base object for vertex type  (Read 2698 times)
Morne
« on: April 11, 2019, 12:34:32 pm »
Hi all
I have 2 objects A and B, that I want to stick on a spline's vertexes. It should alternate between the 2. I thought I can set every 2nd vertex to a corner and every other one to a bezier. However, the base object A is then only placed on the corner vertex and B doesnt do anything
I then made all vertexes corners, and stuck my 2 objects into a sequence operator. This sort of works, however I have the spline split into more than 1 spline and also want every other one to start with B instead of A
I'm getting this:
Image this sort of thing:
A B A B A B A B A B A B A B A B A B A B A B A
then next spline (which is attached to 1st)
But I want this:
B A B A B A B A B A B A B A B A B A B A B A B
« Last Edit: April 11, 2019, 12:37:03 pm by Morne »
Re: Different base object for vertex type
« Reply #1 on: April 12, 2019, 10:39:08 pm »
I used XVertexIndex parameter and created this style:
Please select splines You want to start from B instead of A and set them material id = 2.
Hope this helps.
