Author Topic: Windows cliping another windows problem  (Read 3321 times)
swavec
« on: September 22, 2018, 09:50:29 am »
I have this problem with clipping windows on windows from other side. Cant make sens of it as it dont happen on all windows from other side of facade.
Re: Windows cliping another windows problem
« Reply #1 on: September 24, 2018, 10:31:34 am »
Please try different Hierarchy Checking modes:
Using By Mat.ID should be the best one in Your case. You just need to assign correct ID to Your window splines.
If that does not help please attach Your file and we will check it.
swavec
« Reply #2 on: September 24, 2018, 11:18:31 am »
That option is grayed out.
« Reply #3 on: September 24, 2018, 11:52:01 am »
It is greyed out because You have set Limits by Mtl ID:
Please disable that and Hierarchy -> None seems to do the trick:
« Last Edit: September 25, 2018, 08:43:41 am by iToo »
