Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Escalator - solid Step problem
« previous
next »
Print
Pages: [
1
Author
Topic: Escalator - solid Step problem (Read 3048 times)
ST3200
Newbie
on:
June 09, 2021, 06:11:42 pm »
I wanted to make an Escalator, but I had a problem with steps : all was flat as ski jump.
I had to change a value in graph window. It seems that it is the Walkway value ( bool ) that have no effect.
It is a bug ? I'm the only one ?
Thanks.
Last Edit: June 09, 2021, 06:14:03 pm by ST3200
Logged
Hero Member
Re: Escalator - solid Step problem
Reply #1 on:
June 09, 2021, 06:30:28 pm »
if your Walkway parameter is Type boolean then the output will be 0 or 1 and the selector starts with value 1.
So you just add an arithmetic node after the Walkway parameter and add a constant parameter with value 1.
Last Edit: June 09, 2021, 06:34:55 pm by Dragan
Logged
ST3200
Newbie
Reply #2 on:
June 10, 2021, 08:22:14 am »
Hi, Dragan thanks for answer.
But in fact it is the "Escalator - solid" from itoo presets... I can't manage to make steps when checking "Walkway".
So I wonder if there is a problem with the bool node.
Logged
Hero Member
Reply #3 on:
June 10, 2021, 10:27:08 am »
Yes, same thing.
Those styles were made in previous versions.
Try to set Walkway type to integer and set value=2
Logged
ST3200
Newbie
Reply #4 on:
June 10, 2021, 10:58:01 am »
Thanks.
Hope Itoo fix this....
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
