Author Topic: variable circuit kerb  (Read 3384 times)
Simco
« on: April 26, 2023, 11:02:44 am »
Hi everyone,
I need to create with a railclone object a variable circuit kerb from a single module which changes his x and/or y dimensions along the spline. The dimensions must change at exact points and of a precise value. Is it possible to do? Maybe using rc spline markers?
I attach a screenshot with kerb module  and an example of the result that I need.
Thank you
Ottavia
Re: variable circuit kerb
« Reply #1 on: April 26, 2023, 03:15:51 pm »
For these purposes, you can use a “set of correspondingly resized pieces” which you can handle by the Compose Operator and position Marker(s) to place these where needed.
« Reply #2 on: April 26, 2023, 03:26:55 pm »
Please feel free to check the attached style to see if that might suit your needs. It's using a bit another approach - ID on Markers controls whether there's 1 - no ramp; 2 - upwards ramp; 3 downwards ramp. The first two data channels then control the start/end size of the ramp.
Simco
« Reply #3 on: April 27, 2023, 09:21:31 am »
Thank you,
I'll try to adapt your solution to my needs.
Best regards
Simco
« Reply #4 on: April 28, 2023, 09:17:47 am »
Hi Michal,
the solution you proposed is interesting but not what I need.
The transition from Ya to Yb (see attached drawing) has variable lenght in X and the module is like the one in the drawing so I can't split it into two parts.
Do you have any other solution?
Thanks in advance
Ottavia
« Reply #5 on: April 28, 2023, 02:11:02 pm »
Hi Ottavia,
I'm afraid, that the RailClone plug-in can't do that at the moment. We'll see what can be done in future releases.
