Author Topic: facade pattern not tiling  (Read 4868 times)
Theo
« on: May 10, 2018, 09:42:46 am »
Wanting to try and get more use out of RC but struggling to get this pattern to tile across multiple angled faces in a line.
I have an object with a pattern modelled into it that tiles fine but when i draw a clipping area spline across the angled faces (1 spline for each face but 1 spline object as a whole) at the end of each face it doesnt continue the pattern where it ended on the face before it.
Whats the best way to handle something like this?
Re: facade pattern not tiling
« Reply #1 on: May 10, 2018, 10:08:54 am »
It is hard to give You any tip without testing it on Your scene. Please attach it so we can see what can be done in Your case.
Theo
« Reply #2 on: May 10, 2018, 12:18:11 pm »
Hi sorry just in the middle of stuff. Cant upload the file right now. its pretty much a zigzag shape (but a bit more subtle) with a pattern following across it. i just need it to continue and bend round each angle rather than stopping and starting again. I think maybe not using a clipping area would be better so that it follows a spline at the base and then using a clipping area to cut the tops off rather than using it as the area to fill. but i think those only project in one axis? so not sure how that would affect when the building returns down the side.
not sure this is making sense. if i can get the file up later i will.
« Reply #3 on: May 10, 2018, 01:11:20 pm »
That would be my suggestion too.
Theo
« Reply #4 on: May 10, 2018, 04:09:02 pm »
That method worked! The only issue is it ends with the object sliced open on the end. I cant seem to offset where the objects start instancing from along the spline without it shifting the whole thing along and leaving empty space.
I just need an X offset to push it along a little till it ends on a whole object but there is only Z and Y offsets =/
« Reply #5 on: May 10, 2018, 04:22:25 pm »
Try to use X transform on segment node. Also disable slicing in the same node segment.
Theo
« Reply #6 on: May 10, 2018, 04:36:40 pm »
I think i've done it, had to adjust clipping spline to snip the end off from x transform but the end piece is whole now. Thank you
