Author Topic: Xref and merge crash with this basic RC object?  (Read 2949 times)
DM5847
« on: February 10, 2023, 11:55:44 am »
I've posted on here before about xref crashes with RC objects. Back then it was down to using older RC's from previous versions.
However we've recently been having issues with very basic objects that are newly made, as attached in the link. One of the potential issues I can think of is that it is using a bercon map. The other object that gave us the same issue earlier in the week was also a simple object with Bercon. But maybe you guys can check it and find another reason / fix. File is saved as max2021, latest vray and RC/FP. Collapsing the RC to poly fixes the issue.
https://we.tl/t-yW8GVYKWYZ
Thanks!
Re: Xref and merge crash with this basic RC object?
« Reply #1 on: February 10, 2023, 02:56:38 pm »
I'm sorry to hear, you're facing these troubles. I’ve done some tests with the provided scene, but up to now, I've been not able to reproduce the mentioned issue here. Please feel free to send us the minidump file of the crash. Hopefully, it'll point to the problem source. Thanks in advance.
