Author Topic: RC 3.0.7 where did all libraries go?  (Read 7706 times)
lukx
    • lukxCGI
« on: July 17, 2017, 10:25:45 am »
After installation I got only Architecture Library and Railings, nothing more. Where did it go?
AldingerWolf
Re: RC 3.0.7 where did all libraries go?
« Reply #1 on: July 17, 2017, 10:45:14 am »
...Download new styles and macros from our online repository using Update Manager...
btw...login into the update manager is not working
further, how can i install the libraries on the renderclients?  why is it no more included in the install exe?
« Last Edit: July 17, 2017, 10:47:39 am by AldingerWolf »
lukx
    • lukxCGI
« Reply #2 on: July 17, 2017, 10:51:00 am »
hmmm/....
Pablo
« Reply #3 on: July 17, 2017, 11:05:09 am »
That was going to be my first question :P
By default update manager hides installed packages to simplify the interface. To check installed packages must check View/Installed Packages.
Greetings. Pablo :)
lukx
    • lukxCGI
« Reply #4 on: July 17, 2017, 12:03:56 pm »
... but I still don;t have those libraries in 3dsmax visible.
« Reply #5 on: July 17, 2017, 12:42:18 pm »
The Library now is installed at C:\Users\<username>\AppData\Local\Itoo Software\RailClone Pro\lib\default1
Please, can you check what files are there ? For each library, you should see a folder with an index.xml, max files, thumbnails, etc.
Also send us the file C:\Users\carlos\AppData\Local\Itoo Software\Update Manager\update.log, which include details about the download process.
« Last Edit: July 17, 2017, 12:44:26 pm by iToo »
lukx
    • lukxCGI
« Reply #6 on: July 17, 2017, 12:51:47 pm »
I sent log, and in lib folder there is only Architecture and nothing else
« Last Edit: July 17, 2017, 12:56:21 pm by lukx »
Pablo
« Reply #7 on: July 17, 2017, 01:09:07 pm »
I see that you started using the beta version (thanks!).
Since some important changes occured between versions, Please, take one of these two options:
1) Cleaning the next key from the registry (using regedit.exe)
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\Update Manager\Packages
Alternatively, use the attached .reg (open the zip and double click the .reg file).
2) Reinstall Railclone.
Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Greetings, Pablo :)
« Last Edit: July 17, 2017, 06:00:15 pm by yuv »
lukx
    • lukxCGI
« Reply #8 on: July 17, 2017, 01:43:56 pm »
Big Thanks! All  libs are there now :)
KiboOst
« Reply #9 on: July 18, 2017, 08:53:14 am »
Where can we download libraries ? I mean, without update manager (one more tool just to get some files), to deploy them silently.
« Reply #10 on: July 18, 2017, 09:27:17 am »
Liraries only can be downloaded using Update Manager. Please, see this entry FAQ for more information.
