Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
having a brain fog moment - overlapping segments
« previous
next »
Print
Pages: [
1
Author
Topic: having a brain fog moment - overlapping segments (Read 2784 times)
grue
Full Member
on:
August 09, 2023, 08:14:22 pm »
attached i have 1 shape that i've copied and moved to show an example of an overlap i would like to achieve with just the 1 segement. this is a plan view or top-down view.
this is a 1s array and the segment represents a metal panel that is put together and used as siding on a building or screen wall.
i have a rectangle that i am cloning the metal panel segment around, it works great, but i can't for the life of me figure out how to overlap the segments to show like my example?
Logged
Hero Member
Re: having a brain fog moment - overlapping segments
Reply #1 on:
August 09, 2023, 10:10:36 pm »
Simple padding should do the trick.
Logged
ITOOSOFT
Hero Member
Reply #2 on:
August 10, 2023, 08:13:09 am »
As already mentioned by Dragan, adjusting the
Padding
value(s) of the corresponding Segment will do the trick – in this case, you should enter
negative values
Logged
grue
Full Member
Reply #3 on:
August 10, 2023, 03:06:42 pm »
that is it!
it turns out that the problem was, the whole object wasn't updating when i was using the spinners to adjust the padding. this morning i set to a pos or neg value of like 5ft and happened to click away from the spinner box before it updated. thanks.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
