Author Topic: Hit and Miss Brick help  (Read 22543 times)
LC3D
« on: November 07, 2024, 12:59:07 pm »
Hey all,
I'm trying in vein to create a hit and miss brick using a 2d array with x and y splines...
for the life of me I just can figure it out...
I've attached the file here, if anyone can help me out I'd be very grateful!
Many thanks.
Luke.
Re: Hit and Miss Brick help
« Reply #1 on: November 07, 2024, 02:47:59 pm »
Hi Luke,
Attached is a revised version of your scene. In this version, "Full" and "Half" segments are alternated at the Start and End Inputs using the Sequence Operator. With the Padding parameter, you can easily adjust the Left and Right Padding for segments linked to the Default Input.
I hope this helps.
LC3D
« Reply #2 on: November 08, 2024, 12:57:13 am »
Thanks Michael,
there was no way on earth I would have figured all that out!
You're a lifesaver!
LC3D
« Reply #3 on: November 08, 2024, 02:59:54 am »
Hey Michael,
Sorry, just another question...
do you think there would be any way to create this whole wall with the hit and miss brick in that particular section with RC?
see attached image...?
I'm just not finding a way to make this look realistic...
Many, many thanks...
Luke.
« Reply #4 on: November 08, 2024, 04:01:18 pm »
Yes, for example, you can use the spline’s Material ID to control where it will be applied. Please find attached a revised version of your scene (241108_HitMissBrick_ITOOSOFT.max). I hope that helps.
LC3D
« Reply #5 on: November 09, 2024, 11:44:36 pm »
Thank you SO much! I really appreciate it! :)
