Author Topic: Lights segments not loading from library  (Read 2659 times)
IT1371
« on: August 16, 2022, 07:49:20 am »
So I made a couple of RC styles that i'm loading from my own library. Some of them have an attached vraylight as a segment.
Usually when loading from library the segments are loaded as "embedded" but that is not the case with vraylight which are just empty.
Is there a way around this?
(Yes, I could have just used a mesh with a vraylightmtl, but as we all know vraylightmtl's direct illumination doesn't with a multisub..)
Re: Lights segments not loading from library
« Reply #1 on: August 16, 2022, 11:36:16 am »
Thanks for reporting this. We're looking into the issue. As you point out, it would appear that lights can no longer be embedded causing issues when loading from the library (and also using Proxy Cache > Embedded mode).
I'll reply here once we know more.
Best,
IT1371
« Reply #2 on: August 16, 2022, 12:42:03 pm »
Thank you! looking forward :D
