Author Topic: Texture fix Capping holes  (Read 5240 times)
IVORM
« on: May 07, 2020, 11:54:49 am »
Hi all,
My first post on this forum. I need to find a fix for my textures while capping my assets inside Railclone.
I am working on some intersection visuals and I am using the build in Cap feature inside Railclone. The textures are distorted and I am trying to fix it with a separate poly select and a new UVW map inside my stack. Unfortunate this not a solid fix which doesn't always work. Do you have some suggestions?
Re: Texture fix Capping holes
« Reply #1 on: May 07, 2020, 12:06:09 pm »
Hi and welcome.
You can enable RailClone generated UVs:
Hope this helps
IVORM
« Reply #2 on: May 08, 2020, 12:02:53 pm »
Thank you Rokas! That fixed my issue.
IVORM
« Reply #3 on: May 08, 2020, 02:47:24 pm »
Unfortunately, that doesn't work with a street tile, when I click the apply box mapping.
It doesn't maintain the previous UVW unwrap setting.
« Last Edit: May 08, 2020, 02:49:04 pm by IVORM »
« Reply #4 on: May 08, 2020, 02:50:36 pm »
Please attach a max file to illustrate the problem
IVORM
« Reply #5 on: May 08, 2020, 02:54:35 pm »
Here you are Rokas!
« Reply #6 on: May 08, 2020, 03:30:52 pm »
Thanks. OK yes, this method only works with simple BOX mapping and seamless textures. I guess this time You can swap the tiles texture to seamless concrete material.
IVORM
« Reply #7 on: May 08, 2020, 05:09:44 pm »
Thks for your advice, that seems to be the best solution.
nubo
« Reply #8 on: August 05, 2020, 03:06:36 pm »
I've noticed that cap mapping size is incorrect when using non real-world mapping, specifically it's got different scale than the body of the segment.
It gets fixed when I switch to 'real-world map size' in RC and to 'real-world scale' mapping in texture.
I work in centimeters.
Is there any fix for that? I'd rather not work in RWS mapping, since most of our libraries are based on regular UVW-tiling mapping.
Przemek
« Last Edit: August 05, 2020, 03:21:16 pm by nubo »
« Reply #9 on: August 05, 2020, 03:29:26 pm »
I am afraid not, only RealWorldScale when capping.
I use both RWS and regular UVs on daily basis. Both have own pros and cons.
NL4355
« Reply #10 on: April 15, 2023, 11:53:02 am »
Is this solved already or still an issue? Can I Box Map caps separately?
« Reply #11 on: April 17, 2023, 10:09:14 am »
I'm not sure about the original problem, because this is an old post and we made many changes since then.
But actually Segment->Mapping options applies also for Caps, and coordinates can be specified in RWS or regular units.
If you have a problem with that, please create a new forum thread and attach a sample scene. We'll check it.
Thanks.
