Author Topic: Missing polygons on roof edges  (Read 28866 times)
Larus
« on: April 25, 2025, 11:47:55 am »
not sure what could be the issue here.
Some edge tiles are missing polygons (attached screenshot). It renders like that also.
I've used default style without any adjustments.
Thanks!
Re: Missing polygons on roof edges
« Reply #1 on: April 25, 2025, 12:08:40 pm »
Disabling the Deform > Bend and Deform > Slice options should help prevent any deformation or slicing of the segments used for verges. If you continue to experience issues, please feel free to send us your scene - ideally simplified and containing only the problematic object(s). Thanks in advance.
Larus
« Reply #2 on: April 25, 2025, 12:19:50 pm »
Unchecking Slice and setting to Preserve (remove was at default) in Generator worked but another problem comes up. Edge tiles sticking at the top... So, I returned all to the default and just add little X offset (0.5cm).
« Last Edit: April 25, 2025, 12:27:33 pm by Larus »
