Author Topic: need help with cuban style gold chain  (Read 3160 times)
Uwe Kreuzahler
  • 3D Visualization Director
    • 3D.CR
« on: January 08, 2022, 09:30:39 pm »
Hello
I'm using railclone to create a golden cuban chain and i run into some issues when i try to fold it around the neck
I did try to rotate the vertice, currently set as bezier, but with no effect
When i set that vertice to bezier-corner then i can rotate the vertice, but the railclone breaks the chain. See screen2.jpg
Currently the railclone is set as shown in screen3.jpg (only added the distance)
Any idea how i can get this solved?
Photorealistic Architectural Visualizations
www.3D.cr
Re: need help with cuban style gold chain
« Reply #1 on: January 08, 2022, 10:00:52 pm »
1. Can you share the scene file?
2. You can use RC Spline modifier > banking controls, introduced in the new RC5.
https://www.itoosoft.com/blog/railclone-5-released-banking-support-for-lights-proxy-cache-and-much-more
Uwe Kreuzahler
    • 3D.CR
« Reply #2 on: January 08, 2022, 11:13:21 pm »
Hi Dragan
thanks for your reply
I looked at the link you gave me, and added a marker to the spline, but when i try to rotate that marker the rotate option is greyed out
The original file is close to 1GB, so i did cut everything from the scene, except the neck and the railclone parts (spline, railclone and chain link)
Can you please have a look at it and maybe you can point me to some info how i do the rotation - like shown with the rollercoaster, inside the link you sent me
Uwe
www.3D.cr
« Reply #3 on: January 08, 2022, 11:42:21 pm »
Thank you for the file.
1. Add RC Spline modifier
2. Go to Banking tab >Clik create> Add Banking Markers on spline (additionally tweak Position/Angle)> Clik Create/ESC to exit Creation
3. Now you can select individual Banking markers and  tweak them with Move/Rotate Tool (You need to select Banking in RC Spline Modifier, see pic.)
« Reply #4 on: January 09, 2022, 12:02:48 am »
additionally,
I would use Default distribution (Adaptive mode) with padding, bend off and slice off.
Also, You can increase Curve steps in General rollout.
Uwe Kreuzahler
    • 3D.CR
« Reply #5 on: January 09, 2022, 12:40:27 am »
Hi Dragan
this works perfect
Thanks a lot for your help
All the best
Uwe
www.3D.cr
« Reply #6 on: January 09, 2022, 12:41:51 am »
Glad to hlep  ;)
