Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
problem random size
« previous
next »
Print
Pages: [
1
Author
Topic: problem random size (Read 6310 times)
RL1396
Newbie
problem random size
on:
May 02, 2018, 02:01:56 pm »
When I create a random for the size of the slats, they do not put end to end but are spaced. How to make them follow each other?
Logged
Hero Member
Re: problem random size
Reply #1 on:
May 02, 2018, 02:14:53 pm »
You should switch the x with y.
Attached simple scene. If that does not help- please attach Yours and I will explain in more detail.
Logged
RL1396
Newbie
Reply #2 on:
May 02, 2018, 05:39:04 pm »
I don't think this is the problem.
Here's my file
Logged
RL1396
Newbie
Reply #3 on:
May 02, 2018, 07:29:26 pm »
Thank you. It's the good solution but I wonder why the X/Y axes are in the wrong orientation.
Logged
RL1396
Newbie
Reply #4 on:
May 02, 2018, 11:11:33 pm »
By doing identical tests, I find myself facing different situations. In this case, the boards should have lengths between 50 and 100% of the initial length. Why is not the case?
Logged
Hero Member
Reply #5 on:
May 03, 2018, 08:01:39 am »
Reset your Box001 xform. That should help.
Please attach your scene if it does not.
Logged
RL1396
Newbie
Reply #6 on:
May 03, 2018, 04:03:57 pm »
it doesn't work with "reset xform"
Logged
Hero Member
Reply #7 on:
May 03, 2018, 04:13:10 pm »
You have wired Random number 50-100 to Fixed size. I would suggest to set this parameter as Scene Units. It makes more sense.
If You want to adjust by percentage, You can do that in transform node:
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
problem random size
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
