Author Topic: problem random size  (Read 6313 times)
RL1396
problem random size
« on: May 02, 2018, 02:01:56 pm »
When I create a random for the size of the slats, they do not put end to end but are spaced. How to make them follow each other?
Re: problem random size
« Reply #1 on: May 02, 2018, 02:14:53 pm »
You should switch the x with y.
Attached simple scene. If that does not help- please attach Yours and I will explain in more detail.
RL1396
« Reply #2 on: May 02, 2018, 05:39:04 pm »
I don't think this is the problem.
Here's my file
RL1396
« Reply #3 on: May 02, 2018, 07:29:26 pm »
Thank you. It's the good solution but I wonder why the X/Y axes are in the wrong orientation.
RL1396
« Reply #4 on: May 02, 2018, 11:11:33 pm »
By doing identical tests, I find myself facing different situations. In this case, the boards should have lengths between 50 and 100% of the initial length. Why is not the case?
« Reply #5 on: May 03, 2018, 08:01:39 am »
Reset your Box001 xform. That should help.
Please attach your scene if it does not.
RL1396
« Reply #6 on: May 03, 2018, 04:03:57 pm »
it doesn't work with "reset xform"
« Reply #7 on: May 03, 2018, 04:13:10 pm »
You have wired Random number 50-100 to Fixed size. I would suggest to set this parameter as Scene Units. It makes more sense.
If You want to adjust by percentage, You can do that in transform node:
