Author Topic: Forest Pack Forgets all material editor changes in 3ds Max & Vray  (Read 787 times)
Capital Pixel
I had a project in which I altered the texture of forest pro trees via the material editor using the color correction map. I got all the trees and grass the way I wanted them to be, and it rendered fine. At some point I had to go to another project so I set the project folder to that other project. Later setting the project folder back to the initial project (the one with Forest Pro assets) resulted in all the changes I made to the texture to revert back to their preset state.
When I eyedropper the material that is on the grass it seems to make a new texture from the old altered one, but it also has all the color correction maps and simply not express them anymore.
3dmax 2018
Vray 4.30.01
Capital Pixel
Re: Forest Pack Forgets all material editor changes in 3ds Max & Vray
« Reply #1 on: May 06, 2020, 07:58:33 PM »
Forgot to mention: I've tried re assigning the material through forest pack pro modifier tab setting, and I have tried assigning the old texture (if still stored in the slate editor) but neither express the old settings in render
Capital Pixel
« Reply #2 on: May 06, 2020, 08:52:04 PM »
Not allowing Forest Pack pro to automatically link to its files seems to allow the old settings if I link each map manually. The issue with this is it will no longer keep generated grass geometry at all, and the whole process is very cumbersome.
« Reply #3 on: May 07, 2020, 07:42:01 AM »
Hi thanks for contacting us.
I have just tried to replicate steps You wrote and it works as expected here.
Maybe You did something else to reset custom material.
