Author Topic: Create a seaside promenade  (Read 240105 times)
« on: March 13, 2014, 12:35:42 pm »
Post here your questions and comments about the Create a seaside promenade tutorial.
kadmaster
Re: Create a seaside promenade
« Reply #1 on: November 06, 2014, 12:47:51 pm »
hi,
Very useful tutorial, thnx a lot... I can understand alot of properties of railclone finally. Except one thing... I can't find any UV default material in tutorial files...How can you make this material? Sorry about that but I'm newbie in railclone forestpack and max,too.
« Reply #2 on: November 06, 2014, 02:07:52 pm »
Are you referring to a material like this to help see the effects of the box mapping?
If so I've attached the map I use most often for this purpose. To use simply add it to the diffuse input of any material (depending on the renderer you are using) and apply to the RailClone object.
Many thanks,
kadmaster
« Reply #3 on: November 06, 2014, 03:15:51 pm »
Absolutely, that's what I tried to ask. sorry again for my newbie questions...and many thanks Paul! I'll try to make Uv default material,immediately.  ;)
« Reply #4 on: November 06, 2014, 04:47:44 pm »
Great! Glad I could help out. Let me know if you have further questions.
LILEI
« Reply #5 on: August 18, 2020, 05:45:59 pm »
How is this problem solved in the new version
There is a gap in the corner model
« Last Edit: August 18, 2020, 05:48:39 pm by LILEI »
« Reply #6 on: August 19, 2020, 09:40:40 am »
I've sent you by email a modified version of your scene with the spline "Line03" used as the Y Spline realigned - this way it can be used in the Y/Z mode and you can "disable" the Geometry - X Rotation feature.
Insight Studio PL
« Reply #7 on: April 19, 2022, 12:05:33 pm »
Hi, I have the same corner problem. Maybe You could explain how to fix it so everyone visiting here could do it independently :)
« Last Edit: April 19, 2022, 12:33:49 pm by Insight Studio PL »
« Reply #8 on: April 19, 2022, 03:16:44 pm »
Rotating the spline used as a Y Spline around the X-axis by 90º, using the Reset XForm > Reset Selected, choosing the Geometry > Y Spline Y / Z mode and adjusting the X Rotation to 0 should do the trick.
Insight Studio PL
« Reply #9 on: April 20, 2022, 10:10:20 am »
Unfortunately it doesn't work the way it should. Look at attachments
« Reply #10 on: April 20, 2022, 11:16:17 am »
I see. My apologies - before using the Reset XForm utility, it should be rotated by 90º in the X & Y axes. That should help.
Insight Studio PL
« Reply #11 on: April 20, 2022, 03:06:18 pm »
Still wrong values but I get the idea ;)
Proper values are:
X: -90
Y: 90
Z: -90
