Author Topic: Creating Ceilings  (Read 254367 times)
Re: Creating Ceilings
« Reply #15 on: June 09, 2017, 02:00:39 pm »
It shouldn't be necessary to add another Conditional Operator. By adding the "first" Segment again into the Sequence Operator with the Increment at Y should do the trick. Attaching screen-shot. Hope that helps.
hoshimiya@midasco.co.jp
  • Guest
« Reply #16 on: June 12, 2017, 06:03:41 am »
Thanks. I get what you mean, but say if
lukx
    • lukxCGI
« Reply #17 on: July 17, 2018, 02:59:33 pm »
Is there any easy way to add celling parts with vents and fire alarms? I created those tiles but I'm not sure how I can add them to the ceiling. I don't want them too often but only in few places.
« Reply #18 on: July 17, 2018, 04:09:19 pm »
There are couple of ways, depending on the style You already have. If You attached Your scene (or send us privately) we could help You.
lukx
    • lukxCGI
« Reply #19 on: July 17, 2018, 05:17:18 pm »
grate, let's say I would like to have vents where red circles and fire alarms where X
« Reply #20 on: July 18, 2018, 08:54:27 am »
I reorganized Your style to multiple sequences, it might be easier to understand and edit.
Hope this helps.
lukx
    • lukxCGI
« Reply #21 on: July 18, 2018, 09:35:45 am »
Thank you very much Rokas!
FI4218
« Reply #22 on: April 10, 2019, 03:20:27 pm »
I'm trying to learn more about this excellent tool
I've a simple question about editing the style provided on the tutorial
How can I offset the entire style, keeping the limit boundary, so that my lights can match the cad drawings?
Is there a simple way? Without changing all the segments?
I've tryed the align rules on the array and the transform modifier without success :)
So far my style is the default one No changes
Thank you guys
Keep up the excellent work
Pedro
« Reply #23 on: April 10, 2019, 03:28:13 pm »
Welcome to the forum.
I would recommend to take these steps:
1. Remove spline wire from Clipping Area.
2. Uncheck Extend X/Y Size to Area
3. Set Your own custom X Size and Y size to cover Your needed area and adjust RailClone Object location in the viewport:
4. Then plug in Spline back again to Clipping area.
Hope this helps.
« Last Edit: April 10, 2019, 03:32:14 pm by Rokas »
FI4218
« Reply #24 on: April 10, 2019, 03:46:29 pm »
Hope this helps.
Hi Rokas
Thank you so much for the quick respond
I've did it but the X/Y sizes are locked after step 2...
What am I missing?
Cheers
FI4218
« Reply #25 on: April 10, 2019, 04:09:11 pm »
Hi Rokas
I've got it right Tanks!!! :)
Cheers
