Author Topic: BUG: Surface Area disappears  (Read 2903 times)
DT
« on: December 19, 2022, 01:49:30 pm »
When assigning a surface to a FP object, it doesn't appear in the areas list, so I can't deactivate it, untill I delete it from the surfaces, then it appears in the areas, then I can disable it, and then I can add the surface again. Very strange.
Re: BUG: Surface Area disappears
« Reply #1 on: December 19, 2022, 02:03:03 pm »
Apologies, this is a known issue. Please try deselecting and then reselecting the FP object and the Areas list should update. It should be fixed in the next releases.
DT
« Reply #2 on: December 19, 2022, 04:04:31 pm »
Ok thanks Paul
