Author Topic: FP is offset in my render, but not in the viewport  (Read 3599 times)
Billabong654
« on: December 19, 2022, 04:21:32 pm »
Just as the post read and for the life of me, cant figure out why. Im using UV for the mode. I have tried resetting the xform of my surface. turning off all transforms. Nothing seems to work. Any ideas? Its should be sitting on the yellow roller.
Thanks for any help.
-B
Re: FP is offset in my render, but not in the viewport
« Reply #1 on: December 19, 2022, 04:26:47 pm »
Are any of the objects grouped? If so, try ungrouping them to see if that helps. Otherwise, it's hard to tell from a screenshot, please feel free to email the scene to helpdesk@itoosoft.com and we can take a closer look.
Many thanks,
Billabong654
« Reply #2 on: December 19, 2022, 04:33:13 pm »
Email sent.
« Reply #3 on: December 19, 2022, 05:05:54 pm »
Thanks for the file. It would appear to be because the source geometry is part of a linked hierarchy. Please try the following
- Select Fabric, Fabric 001, and Fabric 002
- Press the Unlink Selection button
- Render or re-build
The objects should then use their own pivots instead of that of the parent object.
I hope that helps
Billabong654
« Reply #4 on: December 19, 2022, 05:13:16 pm »
Thank you so much Paul!  Your a life saver!
-B
