Author Topic: Change item by distance to boundary - dosnt respect probability  (Read 11686 times)
RealViz
    • RealViz
« on: September 04, 2024, 04:02:07 pm »
Hi, I'm trying to create an area border using an effect that will have specifi object. Everything works as it should, unfortunately objects mix with others randomly and do not respect the probability given in the geometry list. In the pictures you can see it on the white objects, which are close to the edge more than in the middle. If I set the white objects to 100%, it behaves correctly or as expected.
Any idea how to do that?
THX
Re: Change item by distance to boundary - dosnt respect probability
« Reply #1 on: September 04, 2024, 04:20:06 pm »
Please try the revised version of the 'Change items by distance to boundary' effects, which now only changes items at the edge. I hope that helps.
RealViz
    • RealViz
« Reply #2 on: September 05, 2024, 09:07:20 am »
Fantastic! Thanks
