Author Topic: Chickweed gone wild  (Read 8791 times)
Bobby Parker
Chickweed gone wild
« on: December 20, 2024, 05:49:52 am »
I can't fix this grass gone wild. It is the Chickweed preset, and that one area has something gone wrong. I tried different seeds, thinking it would move from view, but it stayed there. Any clues?
RealViz
    • RealViz
Re: Chickweed gone wild
« Reply #1 on: December 20, 2024, 07:30:04 am »
You probably have terrain "bend" down at the edge. This, along with "Scale to fit slopes" does exactly that. Best to fix the terrain.
« Reply #2 on: December 20, 2024, 08:15:22 am »
Sometimes, as RealViz has pointed out, the presence of vertical polygons in the object may cause incorrect results when calculating the Surfaces > Scale to fit sloped areas, which might be the case here. A recommended solution is to remove these polygons or disable this feature. I hope this helps.
