Author Topic: Forest pro crashes  (Read 7937 times)
KE3893
Forest pro crashes
« on: September 12, 2017, 08:35:04 am »
Hey,
When I open a blank max, make a shape, create a forest and save it is all fine.
When I re-open that file and select the forest pro it crashes.
I get an error see attachment
Error loading bitmap
C:\Program Files (x86)\Itoo Software\Forest Pack Pro\geometry\images\(some weird squiggles)
KE3893
Re: Forest pro crashes
« Reply #1 on: September 12, 2017, 09:05:47 am »
We are having the same problem as this old thread
https://forum.itoosoft.com/forest-pro-(*)/constant-crash-and-error-message/
We are using 5.4.0 and same problem when I rolled back to 5.3.2
« Reply #2 on: September 12, 2017, 12:20:41 pm »
Sorry to hear, you're facing these troubles. Would you mind to save and send us  the minidump file of the crash? Thanks in advance.
« Reply #3 on: September 12, 2017, 12:39:13 pm »
Actually, most probably there's some script involved. I would suggest you to check scripts you have installed (mainly those under \scripts\Startup) and try unloading these to check if there's any difference (ideally test it on a clean 3ds max installation).
Thanks in advance for any further comments on this issue you can share about it with us / our user community.
KE3893
« Reply #4 on: September 13, 2017, 12:34:51 am »
The dump file should be attached to the first post.
KE3893
« Reply #5 on: September 13, 2017, 12:50:42 am »
Looks like it is a script. Pulled them all out and everything worked as expected. Will go through an test each one individually now
KE3893
« Reply #6 on: September 13, 2017, 05:51:18 am »
We have written some scripts to add attributes to an objects properties.
This is what was breaking forest pro.
« Reply #7 on: September 15, 2017, 10:21:24 am »
Thanks for the update- I'm glad to hear you found a solution to the issue.
If there's anything else we can help with, please let us know.
All the best,
