Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
why forest is squashing geometry?
« previous
next »
Print
Pages: [
1
Author
Topic: why forest is squashing geometry? (Read 5410 times)
lukx
Full Member
on:
January 26, 2018, 09:33:51 am »
Why forestpack is squashing geometry?
Logged
www.lukx.com
ITOOSOFT
Hero Member
Re: why forest is squashing geometry?
Reply #1 on:
January 26, 2018, 03:34:24 pm »
When using "scaled surface(s)" (like on your "Box002" object (207.064 %)) Forest will inherit this scale (and that's not always desirable). In these cases, we usually suggest applying the
Reset XForm
utility over that surface to reset its local coordinates & scale. This will require recreating Forest objects (or apply the
Reset XForm
modifier too, delete it and
Update surfaces data
) to get the right scale. Attaching screen-shots. Hope that helps.
Best regadrs,
Logged
amitgedia
Full Member
Reply #2 on:
January 28, 2018, 05:04:03 pm »
this happened to me once too and i think Paul suggested the same thing of resetting the xform and it worked so i hope this helps you too mate...
Logged
FC1888
Full Member
Reply #3 on:
January 29, 2018, 12:05:23 am »
No geometry, should be scaled, unless you do so, in sub-object mode. If you just have to do it, you should ALWAYS use reset xform, to correct the problems it will most definitely cause later down the line.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
