Author Topic: Warning: can't find object "" in the source scene ?  (Read 24180 times)
Tom_1028
« on: June 17, 2024, 11:26:25 am »
Hi everyone,
I created a Forest Pack object using Spline distribution mode to scatter plants along a spline. It works fine.
Then I created a preset out of this scene.
But when I use the preset in a new scene, I have the message: "Warning: can't find object "" in the source scene". I hit Ok.
A Forest object is created but no objects are scattered. Plus the Forest items appear on the "0 (default)" layer instead of appearing on the usual forest_templates layer.
Can you please help?
Thanks in advance,
Re: Warning: can't find object "" in the source scene ?
« Reply #1 on: June 17, 2024, 11:45:24 am »
Hi Tom,
I'm sorry to hear you're facing these troubles. Could you briefly describe how you created the preset? I've done a quick test with the "Import Objects from Scene..." feature, and everything seems to be working fine. Thanks in advance.
Tom_1028
« Reply #2 on: June 17, 2024, 12:53:27 pm »
Thanks for your support, it's highly appreciated.
To create a preset:
_ I select the Forest Pack object
_ I copy it in a new empty scene (I use a Copy/Paste script found on scriptspot.com)
_ I save the scene in the "objects" folder of the chosen Library folder
_ I collect and relink all the assets
_ I create a thumbnail
_ I create the item in the Library by doing: Create item > Create 3D Object
_ I manually fill the necessary information in the "Properties" of the item
I have to say your method is way faster and convenient, thanks for that.
So I followed your link and created the preset using "Import Objects from Scene..." but it gave the following error:
"Scene File Save Warning: Unable to rename temporary scene file E:\My_Itoo_Presets\...........\objects\xxxx.max.sv$ to scene file E:\My_Itoo_Presets\...........\objects\xxxx.max"
So I hit OK and visibly the process didn't come to an end as I found a temporary file with a .max.sv$ extension instead of the file name I filled in the "Import Objects from Scene..." dialog box.
At that point I renamed the extension of the temporary file to .max, so that it can be found by Forest Pack, and I opened a new empty scene and tried using the preset: it failed with the exact same behavior as I first described:"Warning: can't find object "" in the source scene" + no objects were generated by the Forest Pack object.
PS: I double check I could open the .max: it's working fine. I can modify the Forest pack object, it's rendering well.
« Last Edit: June 17, 2024, 01:00:01 pm by Tom_1028 »
« Reply #3 on: June 17, 2024, 02:37:37 pm »
In that case, could you please send us your scene so we can check it here? Thank you in advance.
« Reply #4 on: June 18, 2024, 08:40:32 am »
Replied by email.
Tom_1028
« Reply #5 on: June 19, 2024, 03:09:51 am »
Thanks for your quick answer and support all the time, really appreciated 👍🏻
MC4813
« Reply #6 on: April 29, 2025, 11:44:47 am »
Hi!
I actually have the same problem creating and using an own preset. Can you please share your solution?
Thank you so much!
« Reply #7 on: April 29, 2025, 11:55:36 am »
Is it possible you're using 'empty Custom Object(s)'? If that's the case, please use the 'Disabled' option instead. I hope that helps.
MC4813
« Reply #8 on: April 29, 2025, 12:18:34 pm »
indeed i did, but that didn´t solve the problem
Any other idea?
« Reply #9 on: April 29, 2025, 02:20:25 pm »
If possible, send us a simplified version of your scene, and we’ll check it here. Thanks in advance.
MC4813
« Reply #10 on: April 30, 2025, 01:02:00 pm »
Hi! It solved the problem. Thank you.
(Yesterday I accidently saved the changed preset in the wrong folder)
