Author Topic: Display  (Read 60910 times)
Bobby Parker
Display
« on: May 30, 2024, 07:23:11 pm »
I have Forest items that I use repeatedly. I merge them, but they are showing as ticks on the beta. It is displaying as if it can't find the proxy, but it renders fine.
« Last Edit: May 30, 2024, 07:34:26 pm by Bobby Parker »
Re: Display
« Reply #1 on: May 31, 2024, 09:12:24 am »
Hi Bobby,
As it's really hard to say, what's happening in your scene just from the provided screenshot - if possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to check it here. Thanks in advance.
CharlyRT
Re: Display
« Reply #2 on: June 01, 2024, 08:47:21 pm »
What kind of Forest Items do u have in your scene?
In a recent project I found that when using vray proxies in the beta you need to show them as full geometry, otherwise they will show extremely small, but it will render fine
« Last Edit: June 01, 2024, 11:26:30 pm by CharlyRT »
RealViz
    • RealViz
Re: Display
« Reply #3 on: June 03, 2024, 08:14:50 am »
Yes this should be corrected. Because a lot of people use VrayProxy even though ForestColor is not working properly (FP8). Their workflow is set to VrayProxy and having everything display on FullMesh is not a very happy solution. It makes the scene take longer to load.
CharlyRT
Re: Display
« Reply #4 on: June 03, 2024, 06:25:21 pm »
I forgot to mention that in prior versions having the proxies on any other display wont affect the Forest Object display at all
What I do is to display as box from 3ds Max display dont know it this affects loading times but it helps me not showing in viewport, also I put all scattered objects in an invisible layer
Hope this could be fixed
Re: Display
« Reply #5 on: June 04, 2024, 12:39:46 pm »
Fixed for next FP9 update.
devalia_mehul
Re: Display
« Reply #6 on: June 04, 2024, 07:31:25 pm »
just curious when will fp9 going to be out
Re: Display
« Reply #7 on: June 05, 2024, 08:37:06 am »
Next beta update will be available soon.
For the the stable release, it's difficult to estimate.
That depends of the reported bugs, suggestions and changes proposed while the beta. But not less thant a couple of months, i guess.
Bobby Parker
Re: Display
« Reply #8 on: June 05, 2024, 06:49:20 pm »
Okay, because it is happening to everything now. This scene is full of Forest Pro elements
Re: Display
« Reply #9 on: June 06, 2024, 09:34:11 am »
This should be fixed in FP 9.0.1b.
