Author Topic: advanced Bend mode 2  (Read 8753 times)
IM1808
« on: January 09, 2025, 11:16:07 am »
Hi, just on the case that the old topic will not see : https://forum.itoosoft.com/railclone-pro-(*)/feature-request-advanced-bend-mode/
Hi, the subject is old but that is possible now ? i have a fence that i want to keep in one mesh and i would like this one follow the surface terrain or line curve (X,Y,Z space) with vertical constraint but not bend. Like there is a new line beetween the evenlys, corner, start, end.
Re: advanced Bend mode 2
« Reply #1 on: January 10, 2025, 09:32:35 am »
Using the Normalize Spline modifier with the Linear Segments option enabled on the base spline and adjusting the Seg Length parameter to match the Evenly Distance should achieve the desired result.
IM1808
« Reply #2 on: January 10, 2025, 11:08:31 am »
Hi and thanks for the answer.
I tried it, and it gave me some results, but the control over "Normalize Spline" is unpredictable or too basic. In my case, I have a spline with Bezier curves, and this tool doesn't give me the ability to set a good and consistent segment length. Also, in the case of a very bumpy surface, I have to use another RailClone (same settings of the fence railclone but with simple plane), which is used to simplify the topography, even if the vertical alignment is unappealing.
