Author Topic: Vray material library error  (Read 3826 times)
Jim Kessler
« on: July 25, 2017, 07:01:45 am »
I accidentally selected the wrong option about setting the paths after install, now I get this.  How can I fix it?  I've tried to uninstall and reinstall of RailClone.
Re: Vray material library error
« Reply #1 on: July 25, 2017, 11:32:42 am »
Hi Jim,
That's really strange. Which RailClone Pro version are you using?
I would suggest you to delete all keys under
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\RailClone Pro
HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\RailClone Pro
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Itoo Software\RailClone Pro
and reinstall the plug-in. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Best regadrs,
Jim Kessler
« Reply #2 on: July 26, 2017, 02:57:57 am »
I'm using RailClone 3.0.7.  I'll give the registry edit a try.
Jim Kessler
« Reply #3 on: July 26, 2017, 03:21:45 am »
Uninstall -> regedit -> Reinstall....did the trick.  Thanks.
