Author Topic: Avoid same objects  (Read 3852 times)
arch3d
    • arch3d.pl
Avoid same objects
« on: February 15, 2018, 04:19:35 am »
I have random piece of geometry on each vertex of a spline ( i dont use material ID in this case )  I would like to avoid same type of adjacent elements. So is it possible for RC to check it and replace geometry?
Michal
Re: Avoid same objects
« Reply #1 on: February 15, 2018, 01:51:56 pm »
To avoid "the same type of adjacent elements" you can split your objects into two groups and alternate between them - for example by the Sequence Operator (this way, the next randomly picked item will be always picked from the "other group"). Hope that helps.
arch3d
    • arch3d.pl
« Reply #2 on: February 19, 2018, 10:41:09 am »
hah good idea!
so easy...:)
thank you very much
