Author Topic: Escalator crashing MAX  (Read 9929 times)
Crayox
« on: April 01, 2025, 03:15:00 pm »
Hi guys,
is this known? On MAX 2023, and RC 6.4.0 I used Escalator with glass handrails and normal CPU vray renderer kept crashing. Figured out the RC steps BLEND material is crashing it. When I used my own alu material for it it stopped.
Re: Escalator crashing MAX
« Reply #1 on: April 01, 2025, 03:35:14 pm »
I've just performed a quick test with the Escalator - Glass Handrails style using 3ds Max 2025 & RailClone Pro 6.4.0, but I couldn't reproduce the mentioned issue—it renders just fine. Could you please specify the V-Ray version you're using? Also, if possible, please feel free to send us your scene - preferably simplified and containing only the problematic object(s). Ideally, if you can reproduce it in a minimal scene, it would be greatly appreciated. Thanks in advance.
Crayox
« Reply #2 on: April 01, 2025, 03:52:10 pm »
vray 7 hotfix 1. Yes, I can send my scene too.
Crayox
« Reply #3 on: April 01, 2025, 04:12:18 pm »
I have 4 copies of the escalator. Maybe that affects it too somehow. Normal copy, not instance.
« Reply #4 on: April 02, 2025, 10:16:55 am »
I've done some additional tests using V-Ray 7 Hotfix 1, but I can't reproduce any issues on my end. If that leads to a "3ds max crash" on your configuration, can you please save and send us the minidump file of the crash? Hopefully, it'll point to the problem source. Thanks in advance.
Crayox
« Reply #5 on: April 02, 2025, 02:39:52 pm »
Just tried to recreate it myself by deleting the object and making a new one again so it picks up the RC material and seems ok now. So I guess it was some freak accident. Will get back to you if I encounter it again.
« Reply #6 on: April 02, 2025, 02:44:13 pm »
I'm glad to hear that it's working fine now. If the issue reappears, please let us know.
