Author Topic: RC2 Array 2splines ... offset Y axis  (Read 13043 times)
JG_archviz
    • JG
« on: April 16, 2014, 11:36:25 am »
Hi I need to figure out, how i could offset the location of an object at the X-axis per every repitition on the y-axis of the array?
I attached an Image to illustrate my Issue.
« Last Edit: April 16, 2014, 11:45:31 am by nakama »
JG_archviz
    • JG
Re: RC2 Array 2splines ... offset Y axis
« Reply #1 on: April 16, 2014, 12:20:53 pm »
Actually i kinda figured a way... but its not yet there....
It should add a certain distance on the X-axis on every Y-counter.
I could reproduce an offset with conditional setting - but not yet one which adds the given value on every Y-counter.
Also i realized a mistake in my explaining image
« Last Edit: April 16, 2014, 12:28:25 pm by nakama »
JG_archviz
    • JG
« Reply #2 on: April 16, 2014, 01:01:50 pm »
I've found a way .... thanks to http://forum.itoosoft.com/index.php?topic=2124.0 the topic before about paving patterns.
My current problem is, that the Facade i was trying to build is not a plane one. instead the X-spline is curved (in this test just as basic example) .... i'd like to get a result like the paving pattern where the overlapping elements are cut and the missing are filled.
Right now the only Idea i got is to create the facade on a plane enclosed spline with the repating paving pattern example... and let that 2S Array projected on a Linear 1S with a curved Spline.
JG_archviz
    • JG
« Reply #3 on: April 16, 2014, 01:11:27 pm »
Ok i created a second RC object... with linear spline and added the previous complec RC object as an segment.
This seems to work - might not be totally correct regarding the sizes due to the curving, but it might work for that purpose.
If anyone has a much more accurate sollution, that would be great.
« Reply #4 on: April 16, 2014, 07:45:44 pm »
This is an interesting style to try and solve. Another approach that requires a little more work upfront is to create a series of pieces that can be used as the first segment of each row.
These can then be wired to a sequence operator in the Left input slot of the generator to create the offset. With the standard alternating sections used in the default. The node tree would look like this:
The disadvantage of this is that if you want to change the offset you have to recreate the side segments. In this example I used a second RailClone object to create and slice these pieces then converted it to an editable mesh and detached the individual pieces. I've attached the scene file.
Hope that helps,
« Last Edit: April 16, 2014, 07:47:27 pm by Paul Roberts »
JG_archviz
    • JG
« Reply #5 on: April 17, 2014, 09:09:38 am »
Thank you, yeah i thought on that workflow too - but decided the strange way.
Currently i'm not knowing how the architects will change the facade during the process - and my strange way gives me the flexibility to change just 2 Elements the Window and the Brick - with some luck it will stay like this :)
