Author Topic: Tutorial - Mapping Tiles and Bricks: Having horizontal scale issue  (Read 5698 times)
RobH2
  • Who is staring at the sea is already sailing a bit
    • NVision4D
The tutorial 'Mapping Tiles and Bricks' is extremely useful and helpful. I am having an issue though.
When scaling the stacked brick on horizontally, it won't scale in small increments. It snaps to larger increments which makes using it in a project problematic. Should you need to line it up with other brick, the joints wind up being either too far apart or too close. I can't just adjust it very slowly to get it perfect. The vertical scaling is fine and you can drive it up and down all you want will ease.
I think it may have to do with the expression used to create the grout width.
if(SegmentXCounter=1,
if(mod(SegmentYCounter,2) = 0,-Input1/2,Input2)
,Input2)
Anyone else had issue with this and found a workaround? I'm not a coder so I can't re-engineer the expression.
ForestPack Pro 6.3.1, RailClone 4.2.13, 3ds Max (Max 2024), GIGABYTE X570 AORUS x570 Master Motherboard, RTX4090, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, Sabrent Rocket NVMe 4.0 M.2 drives
Re: Tutorial - Mapping Tiles and Bricks: Having horizontal scale issue
« Reply #1 on: May 30, 2017, 06:05:59 pm »
If you need to adjust the U/V Tiling & Offset values precisely, you can adjust the Spinner - Precision & Snap settings for these exported parameters under the Preference Settings window (attaching screen-shot) or enter the value from keyboard.
Let me add, that the RC3 includes two easy-to-use Extract Tiles - Stack Bond & Extract Tiles - Running Bond macros.
TL1895
« Reply #2 on: June 05, 2017, 03:26:38 pm »
Hi, I tried the RC3 and wonder if there is a simple way to make a stacked bond version, please?  I tried, but it quickly crashed Max2016 :(
Best regards
« Reply #3 on: June 05, 2017, 03:38:42 pm »
"... wonder if there is a simple way to make a stacked bond version ..."
The Extract Tiles - Stack Bond macro can be found under Macros - UV and Materials. Attaching screen-shot.
"... it quickly crashed Max2016."
Would you please save and send us  the minidump file of the crash? Thanks in advance.
TL1895
« Reply #4 on: June 05, 2017, 04:13:43 pm »
Hi Michal,
Thanks for the screenshot.  I'll try to send the minidump file.
