Author Topic: Segment Scale?  (Read 25902 times)
DT6721
Segment Scale?
« on: August 11, 2025, 04:20:34 pm »
im currently using a L1S to create some sequenced fencing, i have start, end & middle test segments sequenced & plugged into the default node with the generators default rule set to count (to accurately mimic my reference)
my issue is that one of my middle segments needs to retain its dimensions & not scale/stretch ...is this at all possible with my current set up?
Re: Segment Scale?
« Reply #1 on: August 11, 2025, 04:37:23 pm »
Thanks for the question. If you have RailClone 7, you might be better using the new Spline nodes to create this. You can use the divide evenly spline node to add multiple layers of evenly distributed elements. The easiest way to explain is to share a sample scene.
It should be pretty explanatary, but one thing to note is that the Divide Evenly nodes are each assigned a different Material ID. This is then targeted using the Selector node.
If you have any questions about this setup, please let me know.
All the best,
DT6721
Re: Segment Scale?
« Reply #2 on: August 11, 2025, 06:14:21 pm »
Hi Paul,
thanks for the info & scene- ill check out the new spline nodes
in the interim, please find attached my basic test scene, with reference object (black) which hopefully shows what im trying to achieve
Re: Segment Scale?
« Reply #3 on: August 12, 2025, 11:01:27 am »
Thanks for the reference. Please take a look at the attached and let me know if it solves your issues.
Many thanks,
DT6721
Re: Segment Scale?
« Reply #4 on: August 12, 2025, 01:35:40 pm »
great & thanks Paul
is that a bespoke Linear 1S? ...as digging in & trying to replicate, i cant seem to add the extra evenly distance & default count input nodes to a regular L1S (same applies to the numeric default count & evenly distance parameters)?
Re: Segment Scale?
« Reply #5 on: August 12, 2025, 04:09:54 pm »
It's standard L1S. Most parameters can be exported to nodes by right clicking on the node and selecting Export Parameters.
The Number nodes can be found in the side bar under parameters. You can rename them at your own convenience. I've attached a screenshot that I hope helps out.
Best,
DT6721
Re: Segment Scale?
« Reply #6 on: August 12, 2025, 04:38:38 pm »
brilliant & thanks Paul! ...& exactly what i was after :D
