Author Topic: Keep correct Real World UVs - instead of sticking UVWMap on entire RC Object  (Read 2512 times)
Morne
How can I keep the real world maping on segments, even if they get stretched/squashed by the generator?
Only way I can get it to work, is to stick a UVWMap modifier on the entire RC object...
Hi Morne,
For this kind of purpose, using the Apply Box Mapping feature should help.
Morne
Morne
Actually, I want to use a vrayedgestext to make a border around a rectangle object
however, if the generator is set to anything other than scsale, the edgestext doesnt work as expected. I want it over entire RC object, however, its doing it over each segment which for example on adaptive, results in hundreds of segements making up my rectangle, instead of a single object like in the case of scale....
Thanks for your swift reply. Well, as far as I know, that’s the correct behavior of the VRayEdgesTex map – it renders all edges of the geometry.
