Author Topic: Questions about Array2S  (Read 44332 times)
outgribe
« on: September 18, 2013, 12:38:20 pm »
there are some questions about creating array of different kinds of objects.
1. Here are: Array2S with structure like this
with SequenceCog3 (3 oval bottles - 3 boxes)
and SequenceCog4 (1 round bottle - 4 boxes)
It makes something like that
Only 3 (red) sequences match to 3+3 terms and 7 (blue) to 1+4 terms, others are shaken and stirred. =)
Is it a bug or I made something wrong?
2. Every bottle has a different multi/subobj texture with 4 mats inside. When array was created it has no mats at all.
Do I need to create "united" multi/subobj material for all 5 seqments together or there is a way to inherit mats from the reference objects?
3. Is there a way to avoid intersections like this?
Slice is not a choice because it must be a solid.
Regards,
Serge
« Last Edit: September 18, 2013, 01:57:11 pm by outgribe »
Re: Questions about Array2S
« Reply #1 on: September 18, 2013, 05:03:42 pm »
1) Sequence Operators are incremented at each step, regardless if they are used or not by the Randomize operator. Use a Compose operator instead, that should solve the problem.
2) Yes, you must create an unique multi-sub material and assign it to the RailClone object. Unfortunately Max doesn't allow to assign multiple materials to a single object.
3) Try changing "Generator->Geometry->Y Mode" from "Aligned" to "Free". In this way, each array's row is generated independently, according to its length.
outgribe
« Reply #2 on: September 18, 2013, 05:30:31 pm »
Thanks for the answer!
sorry, not completely understood where is "Generator->Geometry->Y Mode"
« Last Edit: September 18, 2013, 05:34:23 pm by outgribe »
« Reply #3 on: September 18, 2013, 06:10:34 pm »
In the general properties of the Array2S Generator.
outgribe
« Reply #4 on: September 18, 2013, 06:44:29 pm »
Ah, "General"...
Yes, it look better but not perfect yet  :)
« Reply #5 on: September 18, 2013, 10:05:35 pm »
I'm afraid it's not possible to remove those intersecting items automatically.
But once completed the object, you would convert RailClone to stand-alone instances using RailClone Tools, and then remove the extra items manually.
outgribe
« Reply #6 on: September 19, 2013, 07:11:15 am »
Thanks again!
Did not hear about this tool before, looks very useful.  :)
