Author Topic: BC verts  (Read 27767 times)
Evgeniy_Ivanov
BC verts
« on: October 04, 2018, 07:22:13 am »
Hey
Can someone tell me how to make a corner object only to be applied on bezier-corner vertices.
Theres a bit of bending on the corner going on also I want to get rid of it: http://prntscr.com/l1ymrh
Re: BC verts
« Reply #1 on: October 04, 2018, 09:14:14 am »
There is a setting just for this, You can find it in Generator, Rules, Corner - Vertex Type:
Hope this helps
Evgeniy_Ivanov
Re: BC verts
« Reply #2 on: October 04, 2018, 03:45:50 pm »
Hope this helps
Nope
Evgeniy_Ivanov
Re: BC verts
« Reply #3 on: October 04, 2018, 04:32:27 pm »
Im setting it to BC but they appear on corner vertices also. How can I avoid this?
http://prntscr.com/l25rad
http://prntscr.com/l25se7
« Last Edit: October 04, 2018, 04:36:05 pm by Evgeniy_Ivanov »
Re: BC verts
« Reply #4 on: October 04, 2018, 04:56:55 pm »
Please attach Your scene. That is the only way we can help You.
Evgeniy_Ivanov
Re: BC verts
« Reply #5 on: October 04, 2018, 05:53:30 pm »
Here
Re: BC verts
« Reply #6 on: October 04, 2018, 09:23:40 pm »
Thank You. I see You are using fillet option. That breaks this bezier selection.
You can remove mid-arc verticies
and form the arc using bezier handles:
Then use Rules- Count mode with value 5 or anything that You like.
Hope this helps.
General tip: try to avoid Scale Mode as it creates more problem than it solves most of the time.
Evgeniy_Ivanov
Re: BC verts
« Reply #7 on: October 04, 2018, 09:38:27 pm »
Hope this helps.
Im sorry but that doesnt work for me. Trying to approximate a circular structure by hand is not what I really want in this situation.
PS: Either scaling or making the geometry bigger...at least scaling is procedural.
Evgeniy_Ivanov
Re: BC verts
« Reply #8 on: October 04, 2018, 10:33:49 pm »
Is there any way to make corner objects appear only on BC verts? Im setting it to BC but they also appear on corner verts X_X
« Last Edit: October 04, 2018, 10:43:47 pm by Evgeniy_Ivanov »
Evgeniy_Ivanov
Re: BC verts
« Reply #9 on: October 05, 2018, 12:48:06 am »
Hello?!
Re: BC verts
« Reply #10 on: October 05, 2018, 07:08:56 am »
You are using fillet option. That overrides Your bezier selection. That seems like a bug. We will try to fix it in next versions.
For now Please don't use fillet option or use "smooth" points inside the arc.
« Last Edit: October 05, 2018, 08:49:12 am by Rokas »
Evgeniy_Ivanov
Re: BC verts
« Reply #11 on: October 05, 2018, 08:53:16 am »
Great X_X
Evgeniy_Ivanov
Re: BC verts
« Reply #12 on: October 06, 2018, 12:02:29 am »
Conditional node doesnt work either?
Evgeniy_Ivanov
Re: BC verts
« Reply #13 on: October 07, 2018, 05:57:59 pm »
So yeah cool, when is the bug gonna be fixed? do I have to pay you another 200$ just to be able to use that feature?!
Evgeniy_Ivanov
Re: BC verts
« Reply #14 on: November 07, 2018, 10:16:59 am »
Since im no longer have an updated license you dont have to help or answer questions anymore?
